- 11 Jun 2013
Also, you can break through 38mph with a few rocks in your rucksack, or preferably, more cake stops
Did the first rider survive?![]()
What can I get for about £500?
Also, I have a CAAD10 105. It has Shimano RS10 wheels. I don't think they're very good.
Is it worth an upgrade to Ultegra groupset over the 2011 105 (whatever 5700???) I have or would I be better getting some lighter wheels from light bicycle or something?
Yay, it's back up!
If anybody is on catching up with uploads from earlier, do me a favour and kudos this ride:
https://www.strava.com/activities/365664389
(Friend's wee boy's first time using strava and he's getting excited about all the kudos)
Definately get new wheels - they make a HOOOOOOGE difference. 105 groupset is just fine for us mere mortals and you won't notice the change (IMHO). I really like my Campy Zonda's which are well within budget![]()
He seeemed to be coming into that corner FAR too fast, anyway?
I fitted my Conti GP4Seasons after finding a cut in my pro4's and have been very impressed, clearance is better too for guards. They were on sale on Wiggle before the weekend (making them cheaper than the GP4000Sii) so I may pick up some more... Grip is incredible!
Got any links to quality discussion on this by any chance? I just can't physically see how it can be possible, particularly with UCI regulations on saddle position.
Cheers, be interested to hear how far fore/aft you are![]()
although I'm not 100% sure hand built are what you need, they're great if you know specifically what you want but for a 'general wheelset' there are much cheaper options.
Better be a good weekend to catch up!Cheers Von, I've sent him a message![]()
Two of mine had saddle bags and pumps, but I doubt that makes much differencea The bottles, yeah, that adds some weight.
been a long time since posting in the MTB thread, but I'm looking to chuck some tubeless tyres on my CX bike, and changing them to tubeless when I get some new rims! What do I need to look out for? I'm after some 700x35ish size, ideally looking for some suitable for early season cross, so hard pack fast rolling, something like a Kenda Happy Medium (although looks to be discontinued).
Also best tubeless kit, I'll be getting some 23-25mm wide rims from China, these will come with a Novatec hub, which I've had great success with on the road bike, but not sure if there is a better more resistant Novatec hub that you guys may have used.
You could easily be looking at half a kilogram with those.
