- 11 Sep 2013
Ah yes, so you did.Note I said typical.
Not disagreeing... But mistakes do happen and NPCs are merciless.If you're side/vertical thrusting in a Vulture, staying off the centre axis/boresight of your foe, then weapons in a fixed variety (especially PA's) aren't going to hit you, unless you are point blank.
I also suspect they can turn faster than they're supposed to, although NPCs usually cheat in games anyway.
Nah, I stopped bothering with chaff/ECM when people started the untarget trick. Besides, it eats into my profits.The only things which will hit you are gimballed/turreted stuff, which you CAN tank in the Vulture and confuse with chaff assuming you're packing a half decent build.
