I'm looking at replacing them with either the Yokohama Advan Sport V105S
Do this, they have stiff sidewalls, perfect for a type R.
Gibbo has them on his M3 and raves about them. They have great wet weather performance too.
Will be the next tyres that go on my S2000 pending a drive of his M3 to see if I like them.
Goodyear Eagle F1 AS2 are highly rated on these.
well they shouldn't be really. They are a good all round sports tyre that are above average in the wet but wouldn't be fitting them to a type R.
This is a good thing on a type R
not really. the FN2 isnt really as compliant as I would have liked it to be but I put that down to the rock hard stock suspension rather than the OE fit tyres.
I drove two FN2s on the same day a few months back, one with F1AS2 and one with RE050As and the difference was huge.
I can imagine that a swap to uprated/progressive springs and keeping the OE fit tyres would result in better ride quality whilst keeping the responsiveness and communication high.
Just need to waif ro my mechanic to get back from holidays and its mapping time
