Need to adjust my chain but whoever had the back wheel out last has tightened the axle nut to within an inch of it's life, can't break it with my biggest ratchet socket so need to grab a breaker bar from somewhere and give it some leverage!
stand on the ratchet and bounce
I use a large adjustable spanner to do mine with,hate it when they overtighten it,only need it so tight the cotter pin will stop it undoing
BKMoto.com
Will update tomorrow![]()
That front tyre is a supercorsa... deffo not a rosso 2.Can't tell from the tread on the rear but at least it's labelled as a rosso 2, what does the rear tyre label say?
Edit: looks a lot like a supercorsa aswell.
If you paid rosso 2 prices, you've got a bargain! However if you plan on riding in the rain... hmmm. Supercorsas are basically road legal track tyres.
Haha, well to be fair the supercorsa tread pattern (or lack of it!!) is rather distinctive.
Just go steady with that front in the rain/cold/damp, it'll have **** all traction unless it's up to temp.
you have less tread pattern,so it wont shift asmuch water
sell it and get a rosso?
id imagine it would warm up less due to less block movement? idk
you'll be alright aslong as you take it steady in the wet,
if you really wanna flog it idk maybe knock £10 or £15 off? courier is usually £10 depends on the weight/size of it
ring and ask a local bike/tyre shop and say I wanna swap it for a rosso plus a few quid ontop see what they say
