i need a new battery for my 07 330i, BMW want £198!
Can anyone recommend one? If i swap it myself will there be any issues with anything?
[TW]Fox;28455134 said:I am somewhat surprised this isn't being done under warranty. What policy do you have?
It isn't listed as an excluded component on the Comprehensive policy and your car is not high mileage...
as others have said not keen on the m4 gts cant they just make the e46 csl with a super charged v8 from the e92now that would be epic!
Out of interest how much have you spent on it since you got the keys?
I know this question wasn't directed at me, but I've spent a lot of money on my E46 M3 (~£1000) and not done more than a few hundred miles in it, however I did plan for this and I did get it below "market" value (based on my constant trawling of the classifieds) knowing that it needed work done. These cars need a lot of maintenance as they get older.
Watch out for them kerbs then![]()
What on earth have you spent £2500 on for personalisation![]()
[TW]Fox;28455160 said:Well the comprehensive policy is a case of 'it's covered unless its listed' and I cannot see it listed in mine. There is a 'wear and tear' clause but frankly I would be surprised if that was genuinely invoked at 50k miles.
Sometimes dealers assume something isn't covered and don't submit it to BMW Warranty for approval...
You can replace the battery yourself, ideally the new one should be registered to the car though so the car knows a new has been fitted and will adjust the charging parameters to match.
Also if you change battery capacity or switch from lead acid to AGM you need register these changes too.
I just fitted a HSB096 (iirc) from Halfords to the 335i as they had a 10% off deal, seemed like a decent price with a 5 year warranty. I registered the battery myself using DCAN cable & tool32 - was very easy.
hmm i don't fancy messing around with things like that, is this something a standard garage can do?
I would have done it if it was just a swap job, but my uncle owns a garage so if its something they can do i can take it there.
