Do employers really care about gaps in employment history? I'm sure the answer is "yes", but I genuinely don't understand it.
If somebody decided to go for a 6 month round the world tour between jobs that would probably even be a talking point on a CV, but if somebody just takes 6 months off and "chills", that's suddenly a big no-no.
depends - it isn't just whether employers care or not but also that you're in a position to be taken advantage of too. If you're in employment and you want a new job then they're going to have to usually bid an amount higher than what you're currently earning. If you're not in employment and you've got a gap that you've got no real explanation for then you're opening yourself up to being valued less. I mean you could try to explain it away as a deliberate gap but the perception is that your previous employment came to an end and you've not been able to find a new job. This might not matter in some place where there are set pay bands but even then could matter in some cases just re: where you fit in terms of banding. It can certainly be a factor where a hiring manager has a wide salary range for a position, they'll see that you've been unemployed for a few months - not much risk of losing you as a hire by giving you a lower salary than they could otherwise offer as you'll probably take it anyway.
Someone going traveling doesn't have that perception issue compared with someone who has been sat at home 'chilling'.
you might well need to get a job and then look for another job in a year - tis much better to job search when already in employment as they have to incentivise you to leave
so found herself with very little to do and soon got fed up of that. Needless to say she was on a reasonable salary and it just so happened that another company head hunted her to work in a support role for one of their systems. She attended an interview and had a few phone calls with the bosses and salary was discussed. They stated a salary 'range' for the role and asked her to submit what she expected to be paid for her role. My obvious response was to demand the maximum and let them negotiate back from there. The point being, they wanted her skill set and she was in the commanding position of being able to negotiate a salary relative to her current wage. They didn't need to know that she hated her current job, they just needed to know that if the offer was good enough, it would entice her away.
