They will just have used a mirror and laser setup - ideally what you want is someone using a hunter (or similar) machine, which you will absolutely get a print out from(or at the very least shown the readigs). Or to go to someone who actually knows what they're doing even wothout one and can set a car up (hint, the garage you've went to won't).
It doesn't mean the car is going to be all kinds of out of alignment, potentially you cant even adjust it on certain axles/axis -but in my experience it is always worth getting it done properly unless your components are worn to buggery
Edit - example from the e46, can't find the last one for the civic
