Just got an Eleaf iStick 50W. Anyone know what a sensible Voltage/Wattage setting would be for a KT Subtank mini with the 1.2Ohm vapor coils would be?
Depends on how you like them. When i was on 1.2ohm coils i never went above 20W max.
ANymore and i would be blown away.
Aim for 4 - 4.2V, so about 13w.
The I50w read a little high I think so maybe adjust slightly for that.
Star at 15 watts and put it up or down as you like. I personally find 25 watts is the highest the subtank likes. Also better to start low and work up until it is how you like it imo Remember and prime puff (take a draw without firing the istick) and leave the tank with juice in it a good 15mins at least before use. Id also suggest putting a few drops on either side of the wick holes to get some juice flowing.
you saying you've got a small mouth?![]()
)If you have any other Kanger style tanks, the drip tip should be interchangeable. The drip tips from a Protank Mini 2 & 3 both fit the Subtank Mini flawlessly
Nice Slinxy, did you add the carbon wrap? looks much better with it.
Im still waiting for notification of my VT200 and Boxer DNA200 being shipped, but the CoilMaster 521 i ordered has been held up due to a recall by CoilMaster, however the site i bought it from had an offer, the first 10 to order get a free Coil Master V3 coiling kit, got an email to say im one of the 10![]()
Great little mod isn't it slinxy
Yeah carbon is a fav of mine i must admit...
Your thinking of the VTBox200 from VapeCig, I ordered the HCigar VT200, different mod.. but still DNA200
Burning Tab... thats the $170 dollar original that the 521 "emulates" lol, i could not justify that money for a gadget, even as cool and the burning tab, the coil master 521 was only £38 inc del from a UK supplier, winning the V3 coil kit was just a great bonus...
