And yet, if filtering was the answer to avoiding the statistically VERY low chance of being rear-ended, why aren't all the riding schools teaching it?
What's that got to do with my post you quoted?
I also hate when they tailgate me,makes my blood boil
It really annoys me when other bikers sit right in my blind spot.
I didn't bring it up again...Are you still going on about this. Jeez.
It's the total cost that kills it.
Rack - £107
Mounting Plate - £42
Fixings Set - £23
Top Box - £240
Even second hand, they're over £350.
Exactly - That's why it's pointless for me. No point in having large luggage capacity if I then have to empty it all out before I can lug it further than wherever I've parked.
Not far off. The Infantry Bergen is 165L.
You shouldn't need to spend more than £200 on a top box. A new Givi V47 can be had for £170 and Givi are pretty much the top end of the market. You can get a Shad top box and fittings for £133 and second hand Givi for much less.
Kappa stuff is basicaly givi under a differnt name and a fair whack cheaper too. easpecialy if you dont mind waiting for shipping from italy when they do some stock clearance on older stuff.
It's an old bike, so yeah some things are pricey.That seems a bit too expensive, although parts may be more expensive for your bike.
A few bikes require one type of rack, with a different plate and then another top box, rather than a set mounting system. It was a Mix & Match solution to cover additional bikes, rather than making a set specificially for those few. Mine seems to be one of those.From what I've seen either the rear rack comes with the mounting plate and fixings or the top box does for many bikes.
The point is that I do need something I can take with me. Backpack, detatchable topbox, something like that. Often parking is quite far from where I need to take the luggage.I'm confused I'm not sure that makes sense. It's like saying a boot is useless if you can't take the boot with you or am I missing something.
When loaded, the pack usually gets strapped to the back, so not a problem.For me I just don't want to be carrying anything on my back should I get into an accident.
Military packs, especially infantry kit, tend to sit above the waist to accomodate webbing pouches.i find most hiking backpacks tend to sit a bit low on the ass for riding, or do you just let it res ton the pillion seat and let that take the weight and really tighten up the shoulder straps to stop it being lose as its lifted by the seat?
