- 2 Nov 2005
- Fife
Ignore - question answered already
Hawaii eh, that's a long way to route your connection![]()
Very close to giving up trying to get my D-link modem work with this ASUS , another 2 hours of my life wasted tonight
Followed instructions above, only info I did not have was to what details to put for WAN IP.
Anyway, unless anyone can see any setting Ive got wrong (photos below), then Im out !!
http://i1049.photobucket.com/albums/s389/bigbilly50/router settings - internet.png
http://i1049.photobucket.com/albums/s389/bigbilly50/router settings - DHCP server.png
http://i1049.photobucket.com/albums/s389/bigbilly50/router settings - LAN IP.png
http://i1049.photobucket.com/albums/s389/bigbilly50/router settings -Primary WAN.png
http://i1049.photobucket.com/albums/s389/bigbilly50/modem set up.png
http://i1049.photobucket.com/albums/s389/bigbilly50/modem - dhcp settings.png
Set WAN connection Type on router @automatic ip
no authentication, as your modem will be doing it.
If the modem is doing all the authenticating (username, password etc) do I actually need to set it up us a normal PPoA/PPoE connection (not 'bridge') ?
Wait you are setting up Fibre right ?
if its fibre what ISP are you with.
With me being TalkTalk i dont require username/password to connect it just connects
but if your with a ISP that requires username/password you will have to setup PPOE with username/password on your modem and route / Bridge through from modem to Router.
First of all, get a spare HG612 from your on-line marketplace of choice. (BT will get all ****y if you unlock the one they provide).
Unlock using the guide from huawei HG612 hacking
Remove the ptm1.301 WAN connection. This is used by BT to check up on your modem.
Edit the ptm1.101 WAN connection so that it looks like:
WAN Connection – enabled
Service List – INTERNET
Port Binding – LAN1
Connection Mode – Bridge
Bridge Type – PPPoE Bridge
DHCP Transparent Transmission – Disabled
WAN 802.1q – Enabled – VLAN ID: 101
WAN 802.1p – Enabled – VLAN ID: 1
LAN 802.1q – Disabled
LAN 802.1p – Disabled
Connect LAN1 of the modem to the WAN port of your router and you should be good to go.
You can connect LAN2 to your friendly neighbourhood switch and access the modem with your browser / telnet to access line stats.
Here is an example of somebody setting up an HG612 in bridged mode for plusnet, maybe this will help -
http://chevron-2.avatastic.co.uk/index.php/using-an-unlocked-hg612-with-plusnet/
On the ASUS Router side I would give it a factory reset as all your settings are a mess and then set it up again but this time you need to enable one of your LAN ports as a WAN port, if I remember rightly it was somewhere in the Dual WAN vicinity but I do not have one any more to advise on that part.
After eleven and a half months of pain with my DSL-AC68U I've finally escaped.
It developed a fault - The LAN and WAN ports both died. Took it back to PC World and they offered to replace it, without even testing it, no questions asked.
They let me swap it for something else, so I went for a Netgear Nighthawk, which I'll pair with my HG612. Always wanted a one box solution, but for now this is more than adequate. Wifi coverage is better now too.
Amazing customer service from PC World. I never thought I'd say that!
Good luck to all those still persevering!
