The alternative is to go AIO, fancying the Predator 240mm just wondering how quiet they are - I've seen performance benchmarks but not noticed anything about noise yet.
Nothing out at the moment. I hope we get to see some shortly.
@ Kelt - Thanks for the reply. How do you find that AIO ? Any good ? Have never used a water cooler of any sort - last 3 cooler have been CM 212 Evo, NH-D14 and NH-D15.
Really tempted by the 360.
@Mike - thank you for the diagram - I will measure up in the morning when I can get at my PC.
Cheers for the responses !
It will be fine since the rad spacing is offset, meaning it is closer to the left hand side/windowed side of the case than it is to the motherboard.
Have a look at the spacing and you will see.
Didn't know it was wider, i have a normal 240 rad in the top of the define S and using some HyperX fury memory, i have 25mm of space free.
Your mem is 52.5mm and mine is 34.2mm, my rad is 121mm wide.
The extra height of the mem plus the extra width of the rad might be too much by about 5mm.
Maybe sell your mem and get some lower profile stuff while the prices are good.
I think they have holes for leds at the sides of the block.
Yeah, they will be, same holes as other 115X sockets.
