- 30 Nov 2011
all about the zotac 5 year warranty. People will cry when their card dies after 2 years
To be fair, quite a few have 3 years on them too. I'll definitely have sold mine by then
Must say extremely happy with my Palit, would like to ask the other palit owners that are OC'ing what's the maximum they are getting on the core clock as mine will not go above +110
I've pushed it to 130MHz at the moment and 300+ on the memory, how far you pushed your memory?
Just got an evga hybrid to go with my classified for SLI. The hybrids asic is 76.2% and the memory will go up to +600 on each card no problem. Got the core boosted individually on each card so they boost to the same and are stable in Witcher 3 and heaven at 1455 but drops to 1443 from the classy going over 60 degrees. The witcher 3 didn't like the classy going above 1474 (1462 after 60 degrees) anyway so a nice stable clock for SLI and a great memory clock for helping out 4k. Not tried the hybrid clocked on it's own as it's not in the primary gpu slot but may mess around with it at some point. Really pleased as it suits being an sli gpu and noise from both gpu's are not teally loud.
I have mine at +100, which results in an actual boost clock of 1480MHz. The power limit is stopping me going any higher. Could easily bypass that with a modded BIOS, but it doesn't seem worth the hassle for an extra 2 or 3fps.Must say extremely happy with my Palit, would like to ask the other palit owners that are OC'ing what's the maximum they are getting on the core clock as mine will not go above +110
That's a really good memory increase. My Palits dont like to go above 450 it seems
I'm assuming you guys are saying your memory numbers as they are in presented in Afterburner?
Your memory is getting to hot which card are you using.
