Cthulhu V2 fist impressions...
Absolutely superb build quality, all the threading is spot on and smooth, very easy to strip down.
Airflow isn't massive, I usually love big wide open tanks, but this feels like they've gotten the airflow just perfect, not too much, not too little.
Flavor is very good, if the Aromamizer is a 10/10 then this is easily a 9/10, not quite on the same level but still very nice.
Just have a single coil build in just now, 9 wraps 26awg (i think) kanthal over a 2mm driver came out roughly 1.4 ohms, chugging away at 20w, just lovely, clouds (so far) aren't massive - but very dense.
It has a juice control ring, that works and is actually usable - take note Youde.
I have one big gripe with it though, to change decks you have to remove the 510 pin and unscrew the deck from the bottom - no problem? Well not if you have a small flat head driver to hand (which I don't, mine are at work!). They don't provide one, which seems like a no brainer to me, you get a phillips driver and an allen key, no flat head. Surely if China is full to the brim of little blue phillips drivers that get thrown in with every sodding thing you buy they could at least muster up some flat heads?
