Man of Honour
- 14 Aug 2005
- York
I might just take a leap into Android now that I know things like this can be done but if I may ask...how does one actually fully customise the user interface? Textures, Icons, Colours, Shading, Widgets, Fonts etc? Do you need a special program or do you need to be proficient in a graphics app ?
You just need a launcher like Nova Launcher and add the right widgets. Widgets like Dashclock even let other apps hook into it to add more functionality (such as upcoming calendar events, notifications, weather forecast, etc).
The attractive thing about stock Android (for me) isn't really the look or feel but more the lack of bloated skins and apps. Much better to start clean and make Android what you want it to be.
This looks intersting. What does it consist of and can you make the icons smaller (i.e to fit more in a row?)
Thanks
Does anyone make there own theme? If so how hard is it?
It's a theme from MIUI mate off the theme store.
not sure I fully understand - looking at those desktop pictures it looks like there is no bloatware at all (was it removed or just hidden)?
What I would ideally like to do if I go with an android (coming from BB10 OS) is just have a single clean homepage with maybe 10 apps in total including phone app. I'd like to be able to change the quality and textures of the icons, the colour and shading, cripsness of the font etc
Are you saying that this is achievable with Nova Launcher or someone would have to go back to Stock Android and do it from there? Sorry I'm clueless with Android never had or used it before!
have a look here: http://mycolorscreen.com/
you can download zooper 'kits' or use their own 'themer' app.
personally i go for a minimal look with nova prime, rro layers and whatever icon pack takes my fancy.
What do you mean by zooper kits?
