Does OCGuru report your memory as 1750MHz, 3500MHz, or 7000MHz at stock?
Respectively mine was reported at the following (at +296): 1975MHz, 3950MHz, or 7900MHz.
Afterburner reports the middle number, and GPU-Z reports the first number, not a clue what OC Guru reports.. It's pretty confusing so I don't blame you for not being up to speed![]()
There's always the beloved Haswell gpu
I was uninstalling the drivers with DDU and I noticed there were no artefacts in safe mode: due to the lower res I guess.
i had it at 7900mhz and gave error on GTA5 this was after 1hr-30mins of playing, maybe it was my cpu overclock, will keep trying till i get it right
shame even with this card GTA5, at 1080p , 2xAA , grass very high still struggles in rural areas, and i thought 980ti at 1080p was overkill
Is there a problem with Heaven ?
At the end the screen shot says I have 4095mb of VRAM.
Good luck with the RMA either way!
Did you notice any artefacting or anything? Admittedly 7900MHz is kinda high, and my 980Ti is a fairly good overclocker, so feel free to dial it down. You aren't going to notice a huge difference between 7500MHz and 8000MHz in all honesty.
And yeah, Grass on GTA absolutely wrecks your FPS, I just turned mine down a few notches to either medium or high, I don't remember which.
Perfectly normal, mine does too. Speccy even reports it as 2048MB![]()
Yep, but my PSU has a subtle whine too, so I'm not sure if it's a combination of both.
This is my third G1, and 2nd PSU, so as you can imagine I am fairly tired of it.
