***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Now this is where I need some input; you hear the stories of Titanium burning too hot and it emits toxic fumes. Is 240C safe to vape at? Please share your titanium builds :)
EDIT: done some research.. apparently it doesn't decompose till over 1000F so I should be safe :)
Yeah your safe on TI on a temp control mod, it does not emit crap till over 1200F...
I finally gave in and order a Uwell Crown and RBA deck from SR-Vapes, £28 delivered, sadly only in silver but still the best deal i could find in the UK.
One of our B&M's them in black. £28 without the RBA deck, £3 more than they sell the silver for.
I gave in an put a Rhino 1050mah 3S pack in my DNA200 to compare.
I'll try it for a couple more days but think I'll be going back to 18650s
For the 0.5% of the time I want to use 100w+ then its going to last longer but for an average day 18650s win hands down
Yeah most sites want £23 or more Just for the tank and £8 for the RBA, so £28 for tank and RBA was a bargain.. i can live with silver lol
Im sure the 1050mAh 3S died fairly fast, it cant compare to 2x 18650, you need at least a 1300mAh 3s for that..
By 5pm with 400 Puffs I've or take and 600seconds firing give or take 10 seconds the Lipo was reporting 25% and the 18650s 61%
yeah ive consistently seen 500+ puffs before i get a weak battery message with the 18650's.. running 60w pre heat, punch set to 8 and 35w.. on a .2ohm TI coil with 100% VG and Rayon wick, which for me is two days worth of vaping minus when im driving to and from work as i use a smaller mod in the car.
Just got an X Cube 2 and a Smok Gimlet Clouds tank its got a 0.2 ni200 coil in :)
Just getting used to it, deffo not a portable device but so far my KBOX Nano is getting better flavour :confused:
Just stuck a simple 0.5 ohm dual coil 3mm build in the Aromamizer and oh wow! This is one of the best vapes I've had from a tank. We're talking dripper levels of vapour and flavour. Very, very impressed.
My only complaint is that the stock 4-hole airflow is too much. I've blocked off the two holes that aren't taking air directly on to the coils and that has improved the flavour no end. I've got a dual-hole band coming with the velocity deck but it's something to be aware if.
We shall see how it holds up when it goes in my pocket tomorrow. Not convinced it's going to not leak but we shall see.
It so looks like it will leak to me, but I have read lots of reports that it doesn't. I'm excited to play with it. I haven't done any coil building since genies lol
I was thinking of getting the Fountain v2. It's a Dripper but with a built in squank tank.
Yeah, I was vaping it yesterday at work. I went through 4 tanks during the day and 2 batteries. That compares to my usual 2 tanks and 1 battery with the Aspire Triton which I usually take out and about with me.
Yeah i just got the Crown. Posted thoughts a few pages back. Bottom line is i think it's the business :) I only use my Triton now because i can't afford the juice to use the Crown exclusively. Massive vapour, great flavour, absolutley drinks juice. I'm close to 5-10ml a day and that's switching around with the Triton all day. 0.5 dual coil is great at 60w. I'm not sure i would take it much higher personally. It wicks well given the size of the wick holes, but i find at at 65w - 70w you need to be careful it's wicking properly (watch for bubbles). That being said it does wick incredibly fast if you do push it. I find the 0.25ohm coil is fine at 75w, but then i like a slightly cooler vape. Only criticism is whatever way they induce the vacuum in the tank is not as reliable as say the Triton which you can lung hit to the max continously without any worries. I find with the Crown you have to be more careful and make sure its' wicking, up end it if it isn't. And it only seems to have wickin problems when the top is removed to fill and the vacuum is broken. That being said i have just ordered a 2nd haha.
It will leak if you leave it horizontal, mavity eventually pulls liquid from the wicks and out of the air holes, I just keep the vape band closed off and try store it in a pocket that will keep it as straight up as possible.
Glad to hear your enjoying it thought Rilot, it really surprised me too :)
My mate at work has the Uwell crown, has been running it with the SS coil head in temp mode on his DNA200, it vapes very well, so well that ive ordered one for myself.
It does vape well in temp mode(i use SS 304 Steam engine TCR) , it drinks juice faster than TFV4 with tricoils.To much for me , if i,m going to chuck 70watts plus @ an atomiser then definitely dripper time.
Status
