Yeah, I was vaping it yesterday at work. I went through 4 tanks during the day and 2 batteries. That compares to my usual 2 tanks and 1 battery with the Aspire Triton which I usually take out and about with me.
so...my eGo One mini is utter ** Swear words must be fully starred ** , I'm going to return it (with the 0.5 and 1ohm: it crackles, hot juice spits out via the mouth piece, also juice comes out via the air holes)
I will order something someone suggested :
iStick TC40W
For the tank I'm torn in between Aspire Nautilus Mini and Kanger Subtank MINI Hybrid
I understand this hybrid allows me to use my own coils if I want to..
Any suggestion on what should I pick?
I went for the mini versions as I hope this setup will be fairly portable.
Fot the coils and juices, I guess it will be trial and error
Try some different juice.. A lot of the issues of spitting/hissing and flooding is down to users sucking too hard, not running there devices at a high enough power setting or using high pg juices.
Try getting some 50/50 juice.![]()
Edit: got an Aspire nautilus, too many people complained that Kanger leaked
What's the best batteries these days? My VTC4s are getting pretty warm using the 0.25Ohm Crown coil at 75w. Bought them from a reuptable dealer so i assume they're genuine...
Was going to get some spares anyway, this time from Torchy's ebay shop. Samsung 25R, 30Q? Or the LG HE4s?
I've literally no idea about the machines themselves, but online I've seen gigantic vape clouds, how is this done? Longer draw or altering the device? I can only do so much with a cigarette.
