*** The Official Playstation 4 (PS4) Thread ***
If my PS4 is in standby and I turn it on by ejecting the disc it will not read other discs when inserted. If I then turn it of it gives me 3 beeps after a while then just constantly flashes the light. I have to hold the power button for 15 seconds to force it off....
So, on start up my PS4 says Rebuilding Database and a quick load bar comes up. This lasts no more than 2/3 seconds, after it loads my PS4 continues as normal. At first I thought I may not have shut down correctly but it's every time I turn it on from both Sleep mode and if I've turned the system off. Any help ?
Yes that is the bug.
The issue with the PS4 not recognising other discs after standby is annoying because it's an issue Sony have known about for a while now. They really should have fixed it.
Can't say I've noticed that issue myself, it decided to turn itself on and spit discs out or just decided to eject a disc mid game session is really irritating though.
That sounds more like the disc eject button thing where it activates on a glass surface from static or something.
Thanks, any recommendations on a 2TB drive. Quicker the better ;)
the quickest you can get requires a nyko data bank which you can order from america for less than £40.
then you can use a desktop 3.5" 7200rpm hybrid drive which cost around £60-80 iirc.
so the mechanical aspect is 7200rpm which is obviously faster than 5400rpm laptop drives and the ssd cache is obviously just as fast as an ssd.
so for around £100 you can get a 2TB drive which is lightning fast compared to the stock drive.
i load about 6 seconds quicker into the tower in destiny for example when i'm host in a fireteam of 3 or less.
I just bought the 500Gb PS4 without knowing about these new versions, turns out it's the new version and been around for a while.
I had thought about teh 1TB but was going to upgrade the drive to a SSHD, so didn't see the point.
Yeah I had considered upgrading to a sshd but I haven't looked into if the performance upgrade is worth it. On my PC I still store my games on a HDD and only have the OS on my ssd so I'm sure I'd be OK with just grabbing the 1tb console.
