- 11 Mar 2013
Maybe, I'd just like a little more size for movie watching etc
If it's more for movie watching then it might be worth it, but damn that price is crazy. You could get a 4K 50" TV for that price.
Guys hows the QC on this? I've got this in mind with the Acer predator as well. However I've heard some horror stories with the Acer.
I had a Swift earlier in the year and ended up going through a total of 5 each with more problems than the last.
So does the Asus quality control still suck for this monitor or have they stopped cheaping out on the panels and have the nightmares ended ?
As I have an Nvidia card I'd like a G-Sync monitor but everything else out there is either Acer which looks incredibly cheap or is upwards of £700 which I am not spending on a monitor.
Is it safe to get a Swift or will I go through the endless RMA cycle again ?
Last week I went through 5 replacements all labelled July 2015. Various faults from back light bleed to buttons not working and a strange flicker on one.
I give up on getting a replacement from Asus; as I have read others have had weak replacements.
So,
I bought an Asus laptop power adapter off ebay (following suggestions from the ROG forum) It has exactly the same specs as the official Asus power adapter for the Swift.
I got it hooked up yesterday, and now my swift seems fine. No more random power-on's in the middle of the night.![]()
My Swift has suddenly started having the following issue:
Switching on the monitor after it has been off overnight does nothing. The power switch seems to have no effect whatsoever. Looking inside the vent at the top I can see the little LED which is always there, so it does have power.
The only way I can get it to power up is to unplug it from the mains and plug it back in. After doing this the power switch works normally, until the next day![]()
Mine is only a few months old, no other problems though. I just wonder if this can get worse and it will not power at all after unplagging from mains?I give up on getting a replacement from Asus; as I have read others have had weak replacements.
So,
Last week I went through 5 replacements all labelled July 2015. Various faults from backlight bleed to buttons not working and a strange flicker on one.
I just came back to this topic to ask the same questionMine is only a few months old, no other problems though. I just wonder if this can get worse and it will not power at all after unplagging from mains?
Can you tell us the model number of the Asus laptop power adapter you bought please ?I give up on getting a replacement from Asus; as I have read others have had weak replacements.
So,
