Assetto Corsa
Odd that other tracks don't work either.
This makes me think it's a more fundamental problem. What game mode are you trying to use them on? Not Time Attack I hope?
A lot of tracks don't work on Time Attack, or Time Trial and simply won't appear there. Hotlap is where they will definitely work.
Edit: For reference, it should look like this (although you should have way less tracks, cause I have a different version of Lake Louise):
Sweet, looks like I'll have to pick this up.
How easy is it to create you're own car?
To build the actual car model is a lot of time and work. Starting from base CAD design following images or in some case blueprints/dimensional drawings.....believe that's the case anyways, take a look at the ac forums car model section. Really impressive to watch some very talented people at work
I stuck to making liveries instead :)
Ah ok mate, will give it a look :)
Barcelona track is giving me some frame rate dips on certain corners, mainly turn one.
The last track they added, Zandvoort, is fine using the same settings.
What's your setup?
Could be something to do with AC now using multiple threads for physics, as I don't think much else has changed.
Intel i5 4690K, 8GB RAM, GTX 980TI.
Odd...
Can you access the AC forums? If not;
Try reducing your force feedback rate from the new setting of 350Hz back to 333Hz (which it was in 1.2) in \system\cfg\assetto_corsa.ini
[FORCE_FEEDBACK]
MAX_FF_RATE_HZ=333
You might try knocking it all the way down to 60 just to rule out that option.
Also this, which is what I was kinda referring to:
Same file as in the previous quote.
