***The Vapers Lounge*** 2.0
Status
Not open for further replies.
I would assume he means the potentially dangerous chemicals such as Diacetyl.
Most commonly found in custards and buttery flavours, it's been linked to some nasty diseases when inhaled
I guess I got caught up in the 'some don't work for people bit'. I tend to forget others might not do that much research into what they are using and / or use companies that don't proudly shout about testing for diacetyl and the like.
I have my doubts about popcorn lung but I do believe it isn't worth risking having it in juice. A couple cases could really hit vaping bad as I believe government would be ready to hit the whole industry with controls and putting it into the hands of only pharma or tobacco companies.
That will happen anyway. TPD coming soon.
I'm a bit out of date, the UK just going to go for it? It was sad to watch the vote on it and hear afterward how few had a clue what was going on. I guess that is what happens when most people don't care about MEPs and let people get voted in on small issues.
I can only speak from my own experience, but i find i get a much more enjoyable vape from TI than i ever got from NI, plus it is soo much easier to work with and NI gave me a chemical taste if it got anywhere near to a warm vape, so i just didnt get on with it at all.
Still playing with my Ti coil too, but it does *seem* a bit better on TC...
My favourite so far is actually the non-Sub coil on my Triton, though, which I *believe* is stainless steel?
I can drop to 10w and MTL vape, or crank it up a bit and open the upper vent to get bigger clouds. Clearing out a room in one vape requires the 0.4Ω coil, though.
If sub-ohm is less than 1Ω What would you call 1Ω and above?
Super-Ohm?
Supra-Ohm?
Hypo-Ohm?
My favourite vape for TC is now stainless steel. It works beautifully and the great thing about it is that you can run it in TC or non TC mode whatever takes your fancy. Needs a mod that can handle it though (DNA200, SX350J).
UK has no choice. We are required by law to implement it.
The only chance is the challenge that TW have been mounting. I find it unlikely that it will be successful though.
Guess I remembered the details wrong, I thought there was some leeway in implementing it. Guess I need to go read Clive bate's blog and see if I can get myself up to date. Need to stock up on nicotine (at least for the short term)
You dont even need a drill, I get one piece of wire and loop it so the two ends meet, all you need is something to hold the two ends of the wire together and a bar or rod of some sort to put in the loop at the other end, apply tension and start turning the loop till the wire breaks, job done.
I use a coil master v3 and kuro coiler to do mine, the V3 has two wire holes in it which is perfect to run the two ends through, then i hand twist those two ends to stop the wire pulling out of the holes, put the handle between my knees and the put the handle from the kuro into the loop, pull until tight and pinch the wire close to the handle and then start spinning the kuro handle... takes me less than a minute to wind enough wire to do two coils worth.
I'm trying to visualize that in my head but ain't succeeding :p
Is there a video using that method?
Do most of you sub ohm vapers use high VG juices here? I bought some Mrs Lord and Co Custard Cream and it is not working in the Lemo 2 with a 0.5 coil. Even down to 15w it was terrible but the Dark Passenger by Vguice is super smooth and tastes great.
Not having much luck with bakery flavours. So far I have tried: (tanks are Lemo 2 and Sub Tank Nano)
Liberty by American Desire - Get constant dry hits on 2 tanks.
Nana's Custard Doughnut By Phoenix - As above but really like the taste.
Custard Cream by Mrs Lord - no taste and a bit meh.
Not a bad video for wire twisting.
Takes some practice but not difficult , just do enough for 2 coils to start.
Note that Ti coils can be springy so i would use a smaller Internal dia rod to make coil & see what it comes out as , you can make it less springy but can be risky if you have not had a bit of practice .
Anyone else taking advantage of the 20% ebay flash sale?
Code : CUKFLASH
http://www.ebay.co.uk/itm/Authentic...723993?hash=item210456e399:g:lBEAAOSwA4dWJiqx
- Aromamiser RDTA with both 6ml & 3ml juice capacity top caps
- Both decks, the 2-post Velocity deck & the standard 3 post deck
- both airflow control bands (2-hole & 4-hole)
- Spare Pyrex glass
- loads of spare o'rings & screws
All that for £36.76 delivered. Don't mind if I do.
Was going to pick up a 3ml as a second tank and expected to pay the same amount for just that alone from elegant vapour.
Used the same code to bag a VT200.
Even though I just bought another SX-Mini M-Class the other day. And even though I said I wasn't going to get a DNA200. I just can't resist...........
Hello. My name is Rilot and I have a problem.
Lots on youtube, but most use a drill, but a wee search will find none drill methods like mine, maybe different tools, but same idea.
I would make my own but only have my phone and hard to film and wrap a coil one handed lol
Vapor shark DNA200 ordered :o
Why you no get Wismec, it's due out any day soon?
Yeh 80/20 ratio juices for me in the RDTA OBS Crius or RDA. I never liked Lord & Co juices, pretty much hyped like all the premium juices.
That is so simple and it works, no faffing about. I like :D
I've sub-ohmed straight VG in a Lemo2 when I was a bit under the weather, had no issues with dry/burnt hits @ 0.5ohm 30w
Code : CUKFLASH
- Spare Pyrex glass
Legend, thanks for this man. Just copped one!
Status
