- 19 Feb 2007
- Sol
Tried one of these at a mates place last night, Definitely don't feel the need to swap out my TN Swift any time soon that's for sure.
That's cause you're blind as a bat![]()
In reality I think it's because I don't fall for marketing baloney
I have a Dell 4K IPS right next to my Swift and the difference is minor at best.
really not much difference? I will send back my PG279Q tomorrow because defective thinking about tn version...
I can only comment on what I see infront of me, No reason for me to make up bull.
) and the Dell is one of the better IPS panels and other than the colour saturation and viewing angles there isn't a dramatic difference between them once you have the Swift half decently calibrated. Sure its no IPS panel but it doesn't look out of place alongside a decent IPS panel.
I have the Dell U2913wm next to my TN Swift (well it would be if the Swift wasn't awaiting RMA) and the Dell is one of the better IPS panels and other than the colour saturation and viewing angles there isn't a dramatic difference between them once you have the Swift half decently calibrated. Sure its no IPS panel but it doesn't look out of place alongside a decent IPS panel.
I now have the XL2420T in its place until the replacement Swift arrives and that is another story... absolute eye sore next to the Dell![]()
I have that exact same Dell monitor and was looking to replace it with the PG278Q but to my eyes, there was no comparison. Even with the 144Hz and Gsync, I couldn't handle the reduction in image quality.
I think most of you are due a trip to specsavers.
Hello everyone. Does anyone know when these will be back in stock?
I've had some terrible luck with mine so far, I'm not a fussy person I swear but the first I ordered from SCAN and it arrived with dust under the screen so I sent it back for a replacement and it was out of stock by the time it got back. I got a refund from them and bought one from OCUK and this one arrived with dust again along with a nasty dead pixel, so again I rma'd only to find out the same thing has happend and that they are out of stock, so at the moment i'm down £750 and without a monitor![]()
Actually I have great eyesight, (5/6) and work in the advertising industry as a Retoucher and Graphic Designer so I like to think I have a better idea than most on colour accuracy.![]()
I've owned Iyama Diamondtron CRTs at 19 and 21", NEC, Hazro and Apple IPS screens at 23-27", the Eizo Foris VA 24", a 6 bit TN Asus and now the Swift and none of them have been perfect, I could sit here all day and moan about each of them but as a gaming screen the swift is the best of the bunch.
Calibrate it properly and the difference is minimal. If you're doing anything colour critical professionally you'd want something better than a bog standard 8 bit IPS anyway imo as they tend to band in gradients.
This TN is an 8 bit panel yes, but its not one build for image quality its built for speed. I got a very good gaming experiencing with my Swift but it was faulty and in the end when I went back to my Dell PVA it was night and day, minus the gsync, the dell laughed at it for image quality. No amount of calibration is going to take away the horrendous colour shift from that Swift TN, you cant even look anywhere on that screen and not see it, and I mean anywhere. The vertical shift is insane, that's the just of it. As for the saturation, I'm not going to go there. If you are going to switch on this monitor and only use it for games and thats it, then yeah go for it. If you use it for any desktop work at all (which a lot of people do) then you are not going to enjoy this monitor, its a TN. Another drawback is the zero processing on this, absolutely not one iota of post processing. Awful.
I've been following this thread from day one and I finally took delivery of it yesterday. I was a bit skeptical because of the issues of Acer's offering, but it now sits in between my two dell 24" IPS monitors. Its amazing!
I have thoroughly checked out the monitor for dead pixels and I can't find any. The overclocking to 165Hz works, but for my needs I have it set at 144Hz.
The amount of screen space this offers over my two 1920x1200 monitors is huge. I'm not a huge gamer, but GTA5 for 20mins last night looked amazing. I have a 980ti.
I will be ordering another two of these soon purely for the 'real estate' they offer over my current monitors.
Can you recommend anything to get the colour brightness, contrast etc set up correctly, for free, preferably!
