- 2 Jan 2012
- UK.
Latest Dev drivers giving great performance / stability on GTX 960. Past few Dev and normal drivers have been spot on tbh.
Hi guys,
Swapping out my 780 for an EVGA 970, should I remove the nvidia drivers first. Or can I just slot it in and do a clean install for the 970?
I'd uninstall the drivers, swap cards then install the driver with the "clean installation" ticked. Worked for me when moving from 980 SLI to 980Ti
The .70 and .78 Dev drivers aren't so good for me either. I was really hopeful that these would end my woes..
Can anyone suggest the best driver for a Gigabyte G1 980 ti? I am getting random framedrops (60 to 30) in GTA 5 (consistent with a drop in GPU usage %) and Kernel Mode Trap errors.
I'm on Windows 10. I'm thinking whether it is better to rollback to W7...
There is no 'best driver' for a particular card, except the latest. If you have problems, it is probably a specific problem somewhere rather than just an inherent 'best/worse' case. Not saying you're doing anything wrong, but the drivers could be having trouble with some specific configuration for some software on your computer for some reason or another. With Windows 10 being new and updated regularly, there might be some conflicts going on that rolling back to older drivers just might not solve. In which case your best bet would be to go back to W7 for the time being if your problems are that bad. But that's only if that's the case. It may be something else, who knows?The .70 and .78 Dev drivers aren't so good for me either. I was really hopeful that these would end my woes..
Everytime l update my Drivers l always choose custom with clean install.
Also l don't install the 3D Drivers as l don't need them.
Nvidia Geforce 358.87 WHQL
DriverVer = 11/02/2015, 10.18.13.5887
Release Date: 2015.11.4
http://us.download.nvidia.com/Windo...-win8-win7-winvista-desktop-release-notes.pdf
http://www.nvidia.co.uk/download/driverResults.aspx/93781/en-uk
