@UKDTWEAK
I'm building in a modmaker gboy wideboy case, I prefer the rounded lines, I have that a 22mm fatdaddy 510, and keystone dual 1860 tray and magnets on order from modmaker along with a step drill set. Hopefully it will be here for Monday.
I sat and thought logically, at the moment I need 100 to 120 watts, want battery life and a decent size so a dna133 device will do the trick while I wait out the wismec fiasco and see what prices go like.
Or plan b and the one I like the most is this, been messing with sketch up since last night and have this so far.
Its awkward doing this on a laptop but it is getting there. I'm designing it to use all off the shelf parts, 3x single keystone 18650 sleds, modmaker stainless buttons and a fatdaddy connector. dna 200 sits on a push mount through pin set up. I'm trying to keep is as compact as possible.
I'm undecided if I will go for a magnet door ( easiest) or a slide door(harder to design). I have a problem with magnet doors, I'm of the opinion that in a severe vent in a metal mod I would like the force directed out of the vent holes and away from the user(also dislike vent holes at the top of mods/under hand grip area), magnet doors imo do not offer this, a severe enough vent will just blow the door off and badly hurt the users hand/face.
Obviously its viability depends on A. my skills in sketch up, sketchy at best (see what I did
) and B. the cost to have the body machined.
