No, but if you play fps games for hours at a time then yes, for me at least.
How was the replacement?
Is this worth the extra over the 60hz ips panel for a casual gamer?
IPS...glow...![]()
TN... Grey blacks.
TN... Must sit above monitor or you get a darker image at the top.
Gamma being all over the place, movies and games look washed out. Windows Desktop the most.
Yeah...
Thing is...I would rathher have grey blacks than a spotlight in every corner....
At least it's not as off putting
It's arrived and compared to my old monitor she's a beaut!
What were you coming from?
I have brightness at 11 atm what is yours?.
Install drivers?
Tried searching online (in device manage options) and it says the best driver is installed but clicking driver details says no driver files have been loaded or are needed...
Got the monitor drivers from Dell site and installed and rebooted. No luck.
Have you plugged it into a usb 3 port on your pc?
