I have the soft cell cut off set to 3.2v on my Dual 18650 DNA200, at 55w on a 0.08ohm dual twisted TI coil with 70w pre heat, it shows weak battery once the cells get to about 3.5v due to battery sag, thats with Efest 2800mAh, 35a cells.
Damn it. Got red carded. Oh well, delivery office in the morning then.
Ah damn, i hate that when it happens... i get my orders delivered to work... just in case.
Torchy does some great batteries, i got 4 of the Efest 2800mAh 35amp cells for my Dual DNA200 off him and they are working well but he also does the 3000mAh Samsung 30Q's which are seemingly the best option at the moment.
If youre a member on UKvapers you can buy direct and save a little.![]()
Was gonna hold off on the aromamizer but I broke my Lemo 2had some titanium wire arrive so I could try TC, twisted two 24AWG strands, built a coil and went to put it in, the wires went in to the post holes, but not all the way to screw down, and got stuck. Tried to pull them in or out with pliers and the wires snapped on both ends, so the post holes are jammed. Looking down the screw holes I can see the wire has bent down and is definitely jammed. So, tried drilling them out - no dice, I simply can't drill through the titanium with a drill bit that small. My first instinct was to drill the holes a little larger when the wires were a little tight to begin with, but alas, I ignored it. Screw it, ordered an aromarizer from steam crave, early upgrade
