Caporegime
- 7 Apr 2008
- Lorville - Hurston
why is it not 10th december yet!
I looked at benchmarks for the Skylake i5 vs i7 in the SP4 , and the differences are negligible. Same applies to RAM - since I won't be dealing with massive PS files and the like, I decided to go for this mid spec one in stead.
Where have you seen the comparisons?
I'm holding fire until the i7 comes out, and have trawled the net for a peak at the i7 SP4, but can't see anything?
From what I can tell, they just aren't out to the reviewers yet. Also, if that's true, the IRIS in the i7 when it is released should give some very notable performance increases. It may cripple the battery though.
The big windows 10 update coming tomorrow (hopefully) might help with the crashes.
Do you get firmware updates using windows update?
The only comparisons out at the moment are between the i5 and the Book i7 but the graphics capabilities here are not the same because of the dGPU in the book.
. But for multitasking it's fantastic, much better than what iOS and Android can offer. As a laptop, the touch cover feels like a proper laptop keyboard. I was a bit worried it would feel a tad flimsy like the 3 but it is a major improvement, I can easily type on this for long durations with no problem.The i5/8gb/256gb model.
Download the 64 bit zip folder from here: https://downloadcenter.intel.com/download/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-
Then extract it to desktop. Go to device manager and select the Intel graphics adapter and go to update. You'll need to pick "Browse my computer" and then "Let me pick from a list of device drivers", " Have disk" then navigate to the folder you extracted and go to Graphics and there should be igdlh64.inf, select that and Windows will then proceed to install it. Looking at the driver date this seems to be a month newer.
I only installed it this morning but had to go to work so haven't tested if it's any better yet. A bonus option, with the Intel control panel you can change the graphics performance to max which gives it a nice boost.
My Surface has arrived but it's not a Pro 4...
I guess a new thread here will be ok as it has a tablet.
Is this from the seller I mentioned?
