E46?
Yup! I know tramlining is a problem for most of them, I was hoping decent tyres would see to it
E46?
Since my 2.0 TDI FR has ditch finders on all four corners since owning it, I'm after new tyres to replace them.
Not really wanting to spend more than £70 a corner max. Anyone had either the Potenza RE002's or Sessanta's/Vorti's before? I've had Rainsport 2's on a previous car but want something different this time round. How true are tyre ratings? All rated 'F' for fuel consumption.
What tyre size do you need? I'm sure that are some other alternatives.
Wouldn't necessarily recommend the Potenza's as Bridgestones on the whole tend to be too stiff (or at least when paired with Audi suspension - can't imagine a Seat is much different)
Haven't personally had Sessanta's before, and seems to be almost 50/50 split between people who love them and people who don't.
Oops tyre size would help, yes. Currently running 225/40/18 and any suggestions welcome![]()
Same tyre size as my A3 - at the minute I have Michelin PS3's which seem very good in the wet or dry. Previously had Pirelli Pzero Rosso's but wouldn't recommend them,
Blackcircles are £81 for the Sessanta's and £88 for the Potenzas you mentioned and at those prices, I'd be inclined to pay a few quid more and get something else.
£91 for Goodyear F1A2 - softer sidewalls
£92 for Michelin PS3 - best wet performance (A rated)
£95 for Conti CSC5 - best performance, but faster wearing
If buying from Blackcircles, then don't forget you can use Quidco to get cashback, and you can also claim tesco clubcard points.
So looking for recommendations in same size (205/55/R16).
Have mostly been running Goodyear Efficient Grip Performance.
£95 for Conti CSC5 - best performance, but faster wearing.
[TW]Fox;28882045 said:Careful with the EU tyre ratings, the PS3 will have the worst wet performance of those 3.
Whilst I would tend to agree that the EU ratings are pretty rubbish - in this case they do seem fairly accurate.
Autoexpress puts the PS3 above both the CSC5 and F1AS2 in wet and aquaplaning tests:
http://www.autoexpress.co.uk/accessories-tyres/66051/michelin-pilot-sport-3
http://www.autoexpress.co.uk/accessories-tyres/66054/goodyear-eagle-f1-asymmetric-2
http://www.autoexpress.co.uk/accessories-tyres/66048/continental-contisportcontact-5
My own personal experience with the PS3 suggests that their wet performance is very good (however to be clear, I haven't tried CSC5 or F1AS2).
[TW]Fox;28882647 said:Thats pretty much the only review that shows that though, take a look at the 2015 Evo test and it's 8th overall:
http://www.tyrereviews.co.uk/Article/2015-EVO-Magazine-Performance-Tyre-Test.htm
2015-EVO-Magazine-Performance-Tyre-Test said:Below are the full results. Please note, we've not included aquaplaning scores, or applied any weighting
2015-EVO Michelin PS3 said:Overall: While Michelin had a relatively strong showing in the wet, the Pilot Sport 3 failed in the dry both subjectively and objectively, finishing ninth in both tests. It won the curved aquaplaning test.
Those are usually ok, it will be the trailing arm bolts they are scared of snapping. It does happen and is a fair old disaster if it does.
