***The Vapers Lounge*** 2.0
Status
Not open for further replies.
I can't seem to find any opinion or reviews on the juices at all. Care to link it?
Absolutely, this thread is how I became aware of it and there is a 400 comment thread on the same group. Although, I can't find for the life of me work out how to link to that specific thread/post.
https://www.facebook.com/groups/UKV...&notif_t=group_comment_follow&hc_location=ufi
Wismec has been pimped out, thanks to zapwrapz.
Yes I need to charge her up :p Been going strong on the same charge since Saturday (hasn't been my out and about mod!)
Damn. I ordered some of that Juicy Vapes liquid and accidentally had it sent to my work address....... where I no longer work. Paypal auto filled it and I was in a hurry. I'm an idiot.
Sent them an email. I hope they can change it.
SRVapes do a package deal where you get the tank and RBA together, but it does add about 5-6 £ to the cost, FT is the cheapest place to get the tank and RBA and worth the wait, as for 2 weeks, sometimes it can be fast or slower, i order an OBS Crius on the 16th this month and it arrived on the 24th :)
As for mod suggestions, if you like the size of the istick, have an external charger and your own 18650's, want TC and enough power but cheap... IPV D2 or the newer D3, both on FT and around £28 - £41 delivered.
thank you! and shame on you! (you made me spend money! :D)
I've seen multiple videos about making the coils, with the cheat sticks it seems very easy
I have to start reading about joules and TC
I thought since I'm about to make a big jump I might as well do it on all plans.
SNIP
SNIP
Nice, i already put carbon fibre on the back door of mine but wimped out on the front panel so ordered a wrap the other day which arrived tonight, i went two tone, but i like yours, though we all know i love CF LOL
If you want a nice Custard & Apple flavour, FA do one called CustApple which is REALLY nice imo - takes about 2-3 days for it to come through though, think I mixed that at 5%.
I understand Capella do make an Apple Pie concentrate, but I'd get the Version 2 they do - that doesn't contain any nasty ingredients (Acetoin, Diacetyl, Acetyl Propionyl). ALL of the Capella 'V2' range has zero of these nasty ingredients in FYI.
With my Nic base, I decant 30ml into a little squeezy bottle and use that. Ideally you want to minimise the amount of air getting to your Nic as the Oxygen breaks it down,. I have a little undercounter fridge like yourself so I just keep it in there, had it since around May time and it is the same colour as when I bought it - just keep it out of direct sunlight!
For your PG/VG - I can fully recommend these. Nice big capacity and a huge spout - I just fill it up every now and again when it's nearly empty.
Scales - ideally you want some that measure down to 0.01g. 0.1g is fine for big batches (250ml+) but anything smaller you want some precision ones like this.
Hope this helps bro!
Thanks Gee!
I'll buy those scales, they look ideal. Do I need to buy some weights to calibrate it?
And I'll buy a couple of those bottles for PG/VG and a smaller squeezy one for Nic. Are you keeping your Nic in the main fridge area or icebox?
About Capella flavourings, I'll stick with V2 then. But what about the ones that are neither V1 or V2, do they contain Acetoin, Diacetyl, Acetyl Propionyl? And how would I find out if Flavour Arts and The Flavour Apprentice have nasties?
Thanks Gee!
http://e-liquid-recipes.com/ is a pretty good resource for finding when flavours contain nastied.
Absolutely NONE of the FlavourArt range contain anything we have to worry about, their flavours are blended purely for vaping.
Cancelled my pre order with ecig one and went to my not so local, local B&M to pick up the last wismec Rx in the area. Very pleased with it though it is sat charging at the moment, will be a while before i can get on to it properly.
Also my Chuff stuff liquid is at the postie waiting for me, looks like a day of recoiling and juice testing on my new mod tommorow, hopefully the clone haze dripper tank will be with me along with the HG2 this weel also.
Thanks Gee!
You most likely won't need any weights to calibrate it mate, I used a 10p piece and it was spot on.
I keep my Nic in the main fridge compartment, providing it's kept out of direct sunlight mate you'll be fine.
Here's a link to all of Capella's range that contains ZERO diketones (nasties)
The Flavour Apprentice's (TFA) range will say on their website if it contains any diketones. I understand their 'DX' range of concentrates are free of any nasty business, however just double check on their website first - https://shop.perfumersapprentice.com/
Incorrect, their reformulated Yogurt DOES contain Acetoin, but very small amounts.
Reformulated as a DAP-free flavour due to popular demand, a sumptuous Yoghurt. *The reformulated Yoghurt flavour does contain a small percentage of Acetoin in order to retain its flavour profile; Acetoin is not currently considered potentially harmful according to research conducted by Dr. K. Farsalinos, but we advise against using it at extreme temperatures.
However, every single other concentrate in their catalogue contains ZERO nasties, and have been since 2010. Link here if you want confirmation.
If you've got two hours to kill, watch PBusardo's visit to the FlavourArt factory in Italy - very very interesting.
Part 1
Part 2
__
I've just found FA Tiramisu in my concentrate tin, so I've whipped up some Tiramisu Cheesecake...it is exceptionally good, could be my new ADV! (Shouts to HeadInClouds on Vaping Underground for the recipe!)
Cheesecake Graham Crust (TFA) - 3%
Tiramisu (FA) - 0.5% (Try 1% Tiramisu for a bolder but less sweet vape)
Nice low flavour% recipe already have the tfa graham crust .......Is the flavour more like a desert or a coffee?
Tastes more like coffee to me, I'm really enjoying it though!
This was at 0.5%, anything higher and I can understand why it'll taste a bit naff.
This was the recipe
1.5% FA Cocoa
1% FA Black Cherry
1% FA Brandy
1% FA Cherry
0.5% FA Fresh Cream
0.5% FA Tiramisu
0.5% FA Vienna Cream
This was the recipe
1.5% FA Cocoa
1% FA Black Cherry
1% FA Brandy
1% FA Cherry
0.5% FA Fresh Cream
0.5% FA Tiramisu
Hmm, I've never got along with FA Cocoa in all honesty (nor Chocolate). Not to mention it gunks coils something rotten. Each to their own, man!
______
The Chosen Few (EU based company, sells cheap concentrates - used them before so I can recommend) are doing 10% off e-liquid (Diketone free!) until the 30th.
Use discount code REDDIT5 for an additional 5% off as well.
Ordered some concentrates from them not so long ago, took about 6 days to arrive IIRC.
Still waiting on my eliquid to come from Flavour Boss aka cloudy-dreams. I ordered :
Snake oil
One in the pink
Blue Custard
Since these are made up from the recipes that recreate popular eliquids if they taste good then I am ditching buying retail eliquid as it is getting expensive and I'm fed up of buying ones that just taste horrible or lose their flavour even with steeping. I loved golden road and lushington from Stash eliquids but it is quite expensive getting stuff from America, around £90 for 240ml. (2X120ml bottles inc shipping)
Also I'm using 304SS now and it doesn't even hit thermal protection at 220c unlike Ti. I think I am doing something wrong, it came to 0.17 ohms, dual coil, 5 wraps. The coils are spaced out also.
Status
