CSGO goes 50% off and all of a sudden the godlike players with private profiles are in every game...guess I'll leave this until the next VAC wave now.
If you only play for the rank then yeah, I play it mostly out of boredom or with my friends. I've GE, but that's from solo queueing, if I was desprate I would only play 5 pre-made. But its not about the rank, its only a game in the end.always get a load of hackers when csgo goes on sale, play as normal and just report them all but then again once banned that match doesn't count so you may as well not play lol
it's so refreshing to play, exactly the same mechanics as it was back in the day for the original CS only better!
Going to guess like 15 months old for that screenshotI was going through some of my screenshots and look what I've found!![]()
does demo manager require you to download all your demos before they display in the list
Hi all im having some problems with CS - Counter-Strike Global Offensive
i load it up click on the play option,
Click Find a Game
Click on the Active Duty Group or the other one in the Common map packs,
then theres a box in the middle saying "failed too retrive items from your inventory" and another loading/ server finding box in the top left that just keeps counting up,
ive left it on for upto 75mins before looking for a game but nothing?
what am i doing wrong? is there some option that i need too register or login somewhere? ive downloaded CS from Steam and the only times i play im logged into steam automatically.
help?![]()
is there a video of Richard Lewis being richard lewis i.e. a prat ?
do you have any firewall software installed which could be blocking connections to the mm servers?
apart from what you have done nothing else needs doing.
Hey All, i have posted this under the GPU section but not getting many replies to help with the issue so thought i would try here.
i got a 390 last week on the back Friday sales.
i noticed the fps dropping quite low to 120 - 150 fps which i thought was not normal so i installed MSI after burner and can see that the GPU usage is low and the core speed sits around 500 to 800mhz but the default clock speed is 1040mhz.
i get the same issue is minecraft which sits between 300 and 500mhz. i have put back in my old card Radeon HD 5830 and GPU usage is sitting at 95%+ and doesnt drop at all and a consistent 800mhz core clock.
i have done the following
- Ran DDU and removed old drivers and installed new ones
- Formatted PC and re installed OS (tried W10 and 8.1 had the above issue on both)
- running latest AMD Drivers
- reset bios to defaults
- temps are fine on CPU and GPU
now if i run firestrike from 3D mark Demo software this gives me 100% gpu usage and core never drops below 1040mhz
does anyone have any ideas of what the issue is?
PC spec is a I7 950 @ 4.2ghz
6GB of ram
samsung 850 evo 250GB
 (ps. i used to be an AMD guy but had a lot of freezing issues, switched to nvidia and didnt have any issues, that and i was kind of forced to as the case i won is Nvidia branded - kind of)my max_fps is set to 300
i have tried with 10% and made no difference so i will try and up it a bit more.
my budget was £220 and i did have a 970 but returned it because of the vram issues with them and this was my only other option, didnt have the funds for a 980 otherwise i would have got 1 of them
just strange i can run firestrike with no issues at all.
thought it was a CPU bottle next first off but cant see it being that as firestrike runs without any issues but as o formatted i only have minecraft and csgo installed lol
Unboxed a AWP Hyperbeast last night, Don't know if I should sell it or keep it? I am starting to build up massive amounts of excess weapons now.
