Windows 10
I have no idea why so many people can't seem to do a basic install.
I've installed this on 32 pc's over the past couple of months and the only issue I had was on my own build when updating the BIOS, it deactivated.other than trying to reach the right MS person to give me a key so I could re-authenticate, its been trouble free.
It's more than acceptable and a very good OS.
I agree - although not having total control over updates is a pain.
I used the MCT to put Win10 on the USB stick. But I read that I cannot use my Win7 key if I go down the fresh install route. Or is that incorrect? If it's not then I would happily go down that route as I know I can install all the drivers and such myself.
That is correct. You need to upgrade first in order to register the key, and then after you have activated the upgrade, fresh install after.
So any issues you face on the upgrade, will only be for a few minutes until you Initiate the fresh install.
As in if you are lucky you'll only have to wait 2 hours the second time around instead of 6+ hours :S
I have no idea how so many people just accept Windows 10 as acceptable - the general glitches (my brother just found a fairly big one with regard to display language/input device that seriously makes their programmers look incompetent - do they not do any QC testing any more?) and long update times, etc. make Windows XP look state of the art in comparison.
2 hours? Where did you pluck that figure from?
When I upgraded from 8-10, the upgrade path took a out 20 minutes, then the fresh install path took about the same after.
No drama.
The only major glitch I have had on this os was the actual upgrade from windows update, it just wouldn't work at all but doing it from usb worked wonders.
Aside from that the only mini glitch I had was with the inbuilt mail icon, and strange vpn behaviour which is now all resolved.
Baffles me so many people have issues, or have issues on old hardware compatibility then complain about it, not everything will be compatible forever and that will mainly come down to the 3rd parties instead of Microsoft.
Recent 1511 update:
-Brand new Windows 10 tablet (clean stock install to remove bundled crud) - 2 days old OS install without any extra software, etc. even installed - after sitting on 0% for 6 hours I restarted it... (which is probably what hosed the install) it went into a loop of restoring previous OS, forced update to 1511 until I killed the whole lot and did a fresh install from scratch which "only" took 2 hours that time. (This is not an uncommon complaint however that the 1511 update process sits at 0% or takes significant length of time to do the first bit).
-Windows 10 VM on my main PC that I've been sticking preview builds, etc. onto - not sure exactly how long it took as I alt-tabbed and played Skyrim but it was still in progress 2 hours later and finished sometime shortly after that.
-Test PC with Q9550/GTX970 - took about 2 hours to update to 1511 then had all kinds of issues with the start menu not responding, etc. similar to a post above (not the first time I've had that issue with this system - not sure why) wiped it out and reinstalled and its working OK now.
This is largely just me leaving the OS to do its own thing (other than resetting one system thinking it must have hard locked) so you can't really put the blame on me :P
Must admit that I've been pleasantly surprised by Windows 10. Almost zero real issues. Though mine (my choice here) was a clean retail install from USB3 media.
Though must admit that the large number of red flagged items in Windows Event Viewer makes me smile. Pretty much all when you run them through GOOGLE, turn out not to be "real" issues at all and you can simply ignore them.
Recent 1511 update:
Is that the fall update build you are referring to? Including the vm?
If the installer you have is for the original Windows 10, you're right. If the installer includes the 15.11 update (I.e. was created in the last two or so weeks) you're wrong as you can now fresh install using your existing Windows 7/8 key rather than update, if you want.
Is that version the one get now from the microsoft link or on a different link?
My update experience:
Backup the things and download the ISO for a USB installer.
Create USB installer.
Run setup within the ISO.
Wait around 30 minutes.
Check windows 10 is activated.
Fresh install of the USB installer.
Super easy.
I can't remember where, but I remember a tool for Windows 8 and 10 that allowed you to change the colours of windows and taskbars. It only had two sliders, but it was enough so I could fine tune the colours to exactly how I wanted them - not some excuse for a colour palette that looks like it was designed only for children!
I'm sure the tool was posted on OcUK, but I can't see it. :(
ah of course yeah, I forgot about that.
Super easy.
After my initial error with windows update, this is exactly how its been for me, with the initial install and fall update.
I believe its a reg hack. I will see if I can find it
Just had a Windows pop up asking me "How likely I am to recommend Windows 10 to friends or colleges".
I'm sure soon it will be asking me about the accident I recently had or my PPi I need to claim...
Had something about a 10 minute survey with a chance to win a Microsoft Book :S (think due to being logged in with a live id) lol.
Went ahead again and upgraded Win10 on the gaming machine. This time using the USB stick with Win10 via the Media Creation Tool. Worked so much better and I now have Win10 on the machine working fine so far. Tested out Battlefront and it's very good. Will see about putting it on the main machine (currently using right now) in the next week or so. But thanks for everyone's help. :)
