I have no idea why so many people can't seem to do a basic install.
You can't really blame the users - this is almost entirely people leaving Windows 10 to do its own thing - which you kind of have little choice over.
I've installed this on 32 pc's over the past couple of months and the only issue I had was on my own build when updating the BIOS, it deactivated.other than trying to reach the right MS person to give me a key so I could re-authenticate, its been trouble free.
It's more than acceptable and a very good OS.
I used the MCT to put Win10 on the USB stick. But I read that I cannot use my Win7 key if I go down the fresh install route. Or is that incorrect? If it's not then I would happily go down that route as I know I can install all the drivers and such myself.
As in if you are lucky you'll only have to wait 2 hours the second time around instead of 6+ hours :S
I have no idea how so many people just accept Windows 10 as acceptable - the general glitches (my brother just found a fairly big one with regard to display language/input device that seriously makes their programmers look incompetent - do they not do any QC testing any more?) and long update times, etc. make Windows XP look state of the art in comparison.
2 hours? Where did you pluck that figure from?
Recent 1511 update:
-Brand new Windows 10 tablet (clean stock install to remove bundled crud) - 2 days old OS install without any extra software, etc. even installed - after sitting on 0% for 6 hours I restarted it... (which is probably what hosed the install) it went into a loop of restoring previous OS, forced update to 1511 until I killed the whole lot and did a fresh install from scratch which "only" took 2 hours that time. (This is not an uncommon complaint however that the 1511 update process sits at 0% or takes significant length of time to do the first bit).
-Windows 10 VM on my main PC that I've been sticking preview builds, etc. onto - not sure exactly how long it took as I alt-tabbed and played Skyrim but it was still in progress 2 hours later and finished sometime shortly after that.
-Test PC with Q9550/GTX970 - took about 2 hours to update to 1511 then had all kinds of issues with the start menu not responding, etc. similar to a post above (not the first time I've had that issue with this system - not sure why) wiped it out and reinstalled and its working OK now.
This is largely just me leaving the OS to do its own thing (other than resetting one system thinking it must have hard locked) so you can't really put the blame on me![]()
That is correct. You need to upgrade first in order to register the key, and then after you have activated the upgrade, fresh install after.
If the installer you have is for the original Windows 10, you're right. If the installer includes the 15.11 update (I.e. was created in the last two or so weeks) you're wrong as you can now fresh install using your existing Windows 7/8 key rather than update, if you want.
Is that the fall update build you are referring to? Including the vm?
Is that version the one get now from the microsoft link or on a different link?
My update experience:
Backup the things and download the ISO for a USB installer.
Create USB installer.
Run setup within the ISO.
Wait around 30 minutes.
Check windows 10 is activated.
Fresh install of the USB installer.
Super easy.
I can't remember where, but I remember a tool for Windows 8 and 10 that allowed you to change the colours of windows and taskbars. It only had two sliders, but it was enough so I could fine tune the colours to exactly how I wanted them - not some excuse for a colour palette that looks like it was designed only for children!
I'm sure the tool was posted on OcUK, but I can't see it.![]()
Where does the lock screen get its live images from? My wifes laptop had an awesome photo on today and I want to find it!
That's the one you currently get if you run the Windows 10 Media Creation Tool from Microsoft mate.![]()
Any ideas?
