Hi there
My final and largest delivery, customs stung me on this one, £380 but still the total cost of all this kit landed in the was £2100 from CJ Pony Parts, has taken a month to get here though.
- FRPP Handling Kit (Shocks, Springs, Anti-roll bars, toe links, bushes)
- Steeda Ultralight Linear handling springs
- Steeda G-Trac brace
- Steeda Strut brace
- Steeda differential bushing insert support system
- Steeda Jacking Rails
- STO & SHO front license plate holder
- Front pony emblem fixings
- LED interior light kit
FRPP Handling rear progressive springs, toe links + bushings
FRPP Handling kit dampers/springs etc.
This kit is what transforms the car, gets rid of the bounce/jiggly, tightens the car up and improves handling/cornering. The big shame is that this should have being have the GT PP cars came from the factory, but I guess Ford is a business and if they made it too good then people would not feel the need to upgrade and FRPP sales would go down.
Steeda Differential Bushing insert system
Just tightens up the car, red are softer, black are harder, you can also get billet inserts, I shall probably go with the red inserts so that I don't get any NVH increase, also have a similar kit for my M3, makes a very noticable difference to handling/tightness and how the rear-end breaks away without effecting ride quality, for $100 money well spent.
STO & SHO license bracket
Means no big UK plate on front of my car, this is neater and makes removing the plate for shows very easy.
Steeda strut & G-trac front braces
Tightens up the front-end, the strut brace, well we all know what they do and they typically don't do a lot, but hey I got one.
The G-trac brace is the more important part, it connets the to front wishbones together and makes a noticable difference, did the same on my last Mustang, makes the front-end a lot more direct and more responsive to inputs.
I shall be working on my car a lot, so being able to jack the car in seconds and safely and easily support it is very important, hence the jacking rails, when I have finished all my work I can remove these as they are obviously quite heavy, no point in leaving on though supposedly they do help brace the chassis.
Steeda ultralite linear springs
Though the FRPP Handling kit offers a good improvement over the GT PP suspension I also felt the progressive springs in the FRPP kit are a weak point. Those who know about suspension will know that progressive springs are a compromise, they try to retain comfort and then spring rate increases as the car is driven harder. The downfall is shock absorbers are designed to work at a single spring rate and as such linear springs offer better handling whilst being more predictable and controllable, especially at limits. A few guys in the US with this kit have tried this and were blown away by the results, still good ride quality on the road but the cars sportyness and handling was transformed to a level where it would not really get any better for a road car with odd track day in mind. Only coilovers would offer further handling improvement at the expense of comfort and at great cost.
Some might say why bother, well CJ did me the springs at $240 and no additional charge for shipping, if I had waiting and done a seperate order then it would have being $500+ so for £150 it made sense to get the springs added to my order, saves money in long run.
Also I was shocked at the weight difference, the linear springs are around 2kg per corner lighter, good reduction in unsprung mass right there going on, could also be a reason why other guys who have done this have witnessed a great improvement in handling without any sacrifice in ride quality.
That is it now, all that comes next in a year time is wheels/tyres and a super charger kit.
