- 30 Nov 2011
I was directly responding to you saying the sensors must be expensive, thought you might find it interesting that they cost next to nothing, accelerometers and gyroscopes don't cost much either.
My only reason for commenting in the first place was purely that someone said "the vive will be much cheaper because it is made from off the shelf components and the oculus is all custom"
All I've said is that I fund it unlikely the vive will be much cheaper and that I cant see where there are custom components on the oculus that are off the shelf on the vive, they are either both custom or both off the shelf, no one has managed to point out where this massive cost saving is?
I've worked in industrial automation and used to own a company that was a distributor for the cleanroom industry, I have a fairly good handle on the cost of electronics
You're going off little rat runs to try to disagree with anything I write, but you aren't addressing the original point.
