****Folding@home setup guide****
17 May 2013
West Sussex, UK
I found this link, I'm getting a server error when trying to send the passkey form
https://folding.stanford.edu/home/faq/faq-passkey/
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, root@localhost and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
17 Mar 2009
Scotland
Great update but can I suggest you remove the exclamation marks next to team 10
Someone might just take that too literally. There are two like that in OP one in brackets and the one at the end of the post in yellow.
But needed a refresh so well done mate and thanks.
21 Aug 2014
Manchester
A quick message to say hi to the folding team folk; I've finally gotten around to getting it set up once again on my current rig, under team 10.
CPU - i5 4690K @ 4.5GHz (Temp at 100% - 53 c)
Project 6394 (78, 11, 284)
PPD - 8194
GPU - Gigabyte GTX 970 Windforce (Temp at ~95% - 54 c)
Project 9139 (199, 0, 34)
PPD - 290138
I'll need to tweak it slightly for when the system is in use, or at least get used to any adjustments I'll need to make each time. Already have TeamViewer running so I keep an eye on things regularly as it is.
21 Aug 2014
Manchester
hi there,
whats your folding name? the 970's are great for folding PPD aswell as lower running costs
Same as my username here; Seblirium.
It turns out that for the past few weeks, my FaH client hasn't been working; so it hasn't been folding in that time :confused:. Couldn't get it working last night, but just checked now and all is fine again!
8 May 2014
Thought I'd try this out, anyone got any ideas how to get this working?
*********************** Log Started 2016-10-27T18:57:57Z ***********************
18:59:30:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
18:59:33:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:00:29:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
19:00:30:WU00:FS00:0xa7:ERROR:
19:00:30:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
19:00:30:WU00:FS00:0xa7:ERROR:program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
19:00:30:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/commandline/pargs.cpp, line: 680
19:00:30:WU00:FS00:0xa7:ERROR:Fatal error:
19:00:30:WU00:FS00:0xa7:ERROR:Double command line argument -nt
19:00:30:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
19:00:30:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
19:00:39:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:00:40:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:00:41:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:00:41:ERROR:WU01:FS00:Exception: Could not get an assignment
19:00:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:00:43:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:00:43:ERROR:WU01:FS00:Exception: Could not get an assignment
19:01:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:01:43:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:01:43:ERROR:WU01:FS00:Exception: Could not get an assignment
19:03:20:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:03:20:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:03:20:ERROR:WU01:FS00:Exception: Could not get an assignment
19:03:57:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:04:00:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:04:11:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:04:14:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:11:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:05:15:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:57:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:05:58:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:05:58:ERROR:WU01:FS00:Exception: Could not get an assignment
19:09:39:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:09:42:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:09:59:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:10:02:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:10:11:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:10:12:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:10:12:ERROR:WU01:FS00:Exception: Could not get an assignment
19:14:26:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:14:29:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:15:44:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:15:46:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:15:59:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:16:02:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:16:23:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:16:24:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.243:80: No connection could be made because the target machine actively refused it.
PDW
PDW
21 Feb 2014
What version of drivers are you using for the GPU ?
375.57 are known to cause this fault, go back to an earlier version or get the latest that should now be working with F@H
