Thought I'd try this out, anyone got any ideas how to get this working?
*********************** Log Started 2016-10-27T18:57:57Z ***********************
18:59:30:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
18:59:33:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:00:29:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
19:00:30:WU00:FS00:0xa7:ERROR:
19:00:30:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
![Stick Out Tongue :P :P](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
rogram GROMACS, VERSION 5.0.4-20160919-669094a-unknown
19:00:30:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/commandline/pargs.cpp, line: 680
19:00:30:WU00:FS00:0xa7:ERROR:Fatal error:
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
ouble command line argument -nt
19:00:30:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
19:00:30:WU00:FS00:0xa7:ERROR:website at
http://www.gromacs.org/Documentation/Errors
19:00:39:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:00:40:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:00:41:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:00:41:ERROR:WU01:FS00:Exception: Could not get an assignment
19:00:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:00:43:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:00:43:ERROR:WU01:FS00:Exception: Could not get an assignment
19:01:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:01:43:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:01:43:ERROR:WU01:FS00:Exception: Could not get an assignment
19:03:20:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:03:20:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:03:20:ERROR:WU01:FS00:Exception: Could not get an assignment
19:03:57:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:04:00:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:04:11:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:04:14:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:11:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:05:15:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:05:57:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:05:58:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:05:58:ERROR:WU01:FS00:Exception: Could not get an assignment
19:09:39:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:09:42:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:09:59:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:10:02:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:10:11:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:10:12:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:10:12:ERROR:WU01:FS00:Exception: Could not get an assignment
19:14:26:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:14:29:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:15:44:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:15:46:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:15:59:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
19:16:02:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:16:23:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:16:24:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.243:80: No connection could be made because the target machine actively refused it.
