What about flavour? I've hear mixed result/depends what juice etc?
I'm a newbie, this is my first go at vaping and started off with an RDA straight away. From what most people that I know say, is that the flavour and vapour production is not comparable to a tank. But tanks are less messy and make life easier outdoors. I can refill my RDA outside, but I've to stop and carry tissues with me to clean it ever 2 refills. If I was quitting smoking and looking for an alternative RDA would be frustrating...
BTW I can get 8-9 hits out of mine now, the liquid is pretty thick and it takes longer to soak in.
Edit
I'm dripping on a mech so I need the low resistance and sefave area so I'm running a simple 9 wrap 317L 24ga Stainless Steel which sees me around 60-65w on fresh batteries
You dont need low ohms to get flavour or clouds on a regulated mod, that just eats battery faster...
As for what you should build, that depends on what you find comfortable heat wise and what your mod and atty can handle... also what juice you are using as different PG/VG ratios and flavours can make a difference in the experience.
I hate warm vapour, I prefer to keep it fairly cool. I'll do some research and see what type of builds people do on IPV4-S to give me an idea...
