Man of Honour
- 13 Nov 2009
- Northampton
^ Fixed the vid.
That's a superb piece of engineering, doesn't half sound damaging on the changes though.
Proper sequential boxes always sound brutally clunky to me
^ Fixed the vid.
Not what I wanted before Christmas but I've just coughed up for a new o2 sensor as I'm getting a PO141 error code. (Sensor 2)
How easy is this to swap out as I'll have a go tomorrow?
(EP3 if you can't see sigs)
Ive managed to snap the hinge on the lid of my centre console in an 8th gen Civic. Anyone know somewhere to buy a new hinge? I can only seem to find replacements for US cars :/ no doubt honda will want to sell me the entire arm rest at a silly price.
I bought my arch trims from these guys, didn't have any problems.
. Its just the hinge thats snapped in half. Might get the other half out the centre console and try gluing it .
The real benefit is from decent curved vanes inside the rotor to pump and the holes from the bolted interface help reduce heat transfer into the wheel bearing.
Yeah exactly. And so 2 piece may actually run hotter. Although they are less likely to distort
. If theses were so vital why on earth did you spend money on spoon monoblock calliper and leave old brake disks on !?
