With VO I aim for 20% concentrate, so of 50ml, 40ml would be your nic pg/vg base and 10ml concentrate.
I use a 100% vg base so I typically end up around the 80/20 mark
Oh okay, so for 10ml I would have to use 2ml concentrate. I'll be using 10ml bottle at first, I'll be mixing frozen forest for my mum and myself. Now because I only vape on 0mg, the only time I vape liquids with nic is when I try new liquids off someone.
Now my mum finds the 18mg throat hit to be too harsh and the 6mg was not strong enough. So I'm assuming the 12mg would be ideal, with Kanger Subvod running 1.2ohm coil?
Edit:
Is this right?
Nicotine PG or VG (e.g. http://www.justvape247.com/100ml-72mg-72-nicotine-select-base-14750-p.asp )?
