- 27 Sep 2011
I'd say go for it, it's good value and it certainly helps. Just understand it won't do much when the guy your up against in COD has host advantage or a 200ms jump on you in Halo.
local argos had 1 in stock so ive reserved it but not sure whether to pull the trigger or not.
easilyvery well built with plenty of customisation,i love mine
Definitely the best value for money option compared to Scuf etc. Overall I'm happy with mine though I wouldn't agree the build quality is the best. Mine came with stick drift straight out the box, and the left thumbstick has started to make a clicking sound/feeling when I move it certain directions, which can be a little off putting in the heat of the moment.
Just tried to play Tomb Raider and it needs a 1GB update which it is doing at %1 every 10 mins on my 200mb line. Xbox live is complete crap for a paid for service.....
Edit - Given up.... Microsoft really need to do something about the Xbox live download speeds especially at weekends.
9/10 I go to play on the One and end up on the PS4 as the one takes hours to update anything.
Because it absolutely certainly has to be Xbox Live's fault.
Anyone else reporting similar problems with your ISP?
Everything else is ok and it only effects updates. Its either my Xbox or Live...
I don't know what to do about my Xbox, I don't want to sell it but I can't see me playing it, I think I've just been playing on a mouse and keyboard for too long. Are there any devices available that make it possible to use a mouse and keyboard to play games at all?
Noooo!
dont sell it, then us doing coop is gone forever... unless you sell it and but me a graphic card for my pc haha
