- 19 Jul 2013
- derby
whats it like as a general mod aside from the T/C I never use T/C never seen the need
If they are glowing evenly then it comes down to too much power or bad wicking to cause a dry hit.
What wicking material do you use?
The at subvod will serve you well, nice bit it kit for the price.
I re-wicked it 3 times now, same method as I did with my previous build where the flavour was nice without any metal/burnt taste. As for the cotton I've used Cotton Bacon V2...
Can you take a pic of your wicking? You say the cotton is loose, it shouldn't be loose but not jammed through the hole at the same time. When you've trimmed both sides of the wick, fluff it all out and then 'comb' it, this thins it out slightly and it wicks like a champ!
I noticed earlier you mentioned you had pulsed them that much it caught fire?!
I'm no expert and im constantly learning at the moment but to me those coils look worse than mine after 1/2 weeks of using, all that black gunk must be causing the taste?
Try the UD Clapton wire, iirc it's 26/32, 10m spool for around £6, lovely stuff.
It's this stuff, if you don't mind waiting.That's burnt juice, as soon as you wash them they look like new. But after 2-3 hits they look burnt...
Where from?
I've run out of kanthal, I need wire ASAP.
