Permabanned
- 2 Apr 2013
- North West
860+
Yeah mate I know I need to stop buying them.
860+
So then tell me what sites do you use, because I use 2 sites only. G2A and Kinguin, but clearly they don't cut it for you.
Authorised resellers.
GreenManGaming
Direct2Drive (or whatever it's called now)
GetGamesGo
Amazon sometimes
GamersGate
There are loads of them.
Steam is generally the most expensive place to buy anything outsdie of a sale.
Both G2A and Kinguin are grey market sites, not auth resellers.
I did this:
Change your PC's region to Ukraine
Go to the windows 10 store on your app list and search for Rise of the Tomb Raider
Buy it with your credit card (you'll have to sign in with your microsoft account, or make a new one) and invent an address with a postcode matching the format Jono just posted
Stop or cancel the download and change your region back to UK
Not sure if you have to do the last step, but I did and it worked with the download almost finished at this moment.
Start downloading again
Tried this with my Debit Card but it's not working. Any way around this or do I have to buy this with a credit card?
I used a debit card. Dunno why it's not working for you.
What it is saying?
Did you put just the postcode or did you also add an address?
Maybe they've locked it off?
Looks like they blocked this loophole, seems a few people have tried to purchase through Ukraine and India but ran into the same problem as I.
Has anyone who is UK based, used WinGameStore?
I see they have TransOcean for $4.99, but not sure if it will work in the UK.
All I can say is hurrah to Amazon for selling Witcher 3 for 72p last week.
Looks like it will work in the uk mate, go for it.
