I just want a Arma 3 server that is pure military, are there any servers that play human vs human ?
Have a look for King of the Hill, Wasteland and EUTW.
They are all good PvP servers. KOTH and EUTW are decent to play solo as its easy enough to run solo in the AO (KOTH) or group up in EUTW. I find myself getting bored very easily if I'm playing Wasteland solo though, lack of people to talk to gets boring.
Pretty specific buuut..
Does anybody have an i7 around 4.5GHz, a 980Ti and 1440p monitor?
Would you follow me on a server for 10-20mins so we can compare FPS in the same location? Will paypal you the equivalent of an expensive beer
I've just gone from 1080 to 1440 and the lower fps in the built up areas is hurting a little.. G-Sync helps it a lot but I'd much prefer the higher framerates in the first place
Want to know if I'm going to see a good improvement going from a 980 to a 980Ti.
I'm only on a 1080p monitor but rest of the spec is bang on, if you plugged your 1080 back in we could do the tests and then it'd just be a case of averaging off a few FPS to account for the res upgrade?
But if I'm in the same position as somebody else, looking the same direction at the same time with the same settings then it's going to be somewhat comparable.
