So i'm not really sure if these results mean that with a 30psi difference when oil is sealing the rings that 1,2 and 4 need new rings. As for 3 well maybe that's fine ... no idea.
Put it this way, slightly low compression on one cylinder won't be responsible for it topping out at 60mph. It's far, far more likely you have a problem with the carbs or possibly ignition. It's quite possible you just put a bit less oil in that cylinder than the others since the dry readings are identical.
