- 15 Jul 2006
- Up Carp Creek
Does this mean we'll get an official update soon and All 4 will work?
No not yet.
Has anyone elses Fire TV started randomly turning their TV on by itself? 3 times today we have walked into the living room to see the TV on and the Fire TV displaying?
Wondering why I couldn't connect to my Fire with adbfire to sideload some apps to it since upgrade to FireOS5, found out you need to stop firestarter to allow connection
http://www.aftvnews.com/how-to-sideload-apps-to-your-amazon-fire-tv-using-a-windows-pc/
Just in case anyone else had the same problem!
You can just change one parameter in Firestarter, that's what I did at the weekend.
This is from the adbFire help section -
Device Offline
If you're not using FireStarter try toggling ADB Debugging off then on in your Fire TV developer settings.
For FireStarter users, try these settings:
Enable Background observation: checked
Fallback to Non-ADB Observation: checked
Home detection via ADB: unchecked
Startup Application: FireTV Home
Home button single-click: FireTV Home
Home button double-click: Kodi
Single-click app: clear previous is checked
Double-click app: clear previous is unchecked
Home Detection via ADB must be unchecked.
All4 has only just launched and to be honest 4od was so painful to use I'm 99% certain the issues are their end and you may see it on other devices anyway. 5od I have no idea about.. can't remember the last time I watched ch5Got my Fire TV yesterday, now returning it as it's no good to me. All4 never plays any videos and 5oD now My5 says it's not compatible, so 2 of the big catch up services don't work.
Yes, as long as you have access to wifi and the HDMI ports on the TV.
Stuff
my TV shows shortcut is not working as it used to since Kodi v16.
