***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Best (cheapest) place for Capella concentrates?
Darkstar have them for £4.50 for 30ml but not a large selection.
Vapour Depot have a good selection but is £6.40 for 30ml.
Chefs Vapour - £6.50 for 30ml but popular choices seem to always be out of stock.
Vapable
The E-cig Shop
DNA Vapes are taking Pre orders for the Artery Nugget.
For anyone that wanted a COV Mini Volt, but with TC... this does and extra with an 10w, however it is 200mAh less battery... but for a tiny stealth vape....
well, one of my hair brained schemes actually paid off.
bought some fine stainless mesh, cut out a circle and stuck it under the drip tip, idea is it'll block spitting.
was thinking it might not work as it'll either restrict airflow too much or the blobs will just get sucked right through the mesh, turns out those don't happen and i'm getting a smooth if slightly muted flavour vape.
i love it when something works as intended.
You're using the mesh the wrong way!
seems to work for what i need :D
I prefer mine like this
Probably me, mix at 20% if you find their ready made too potent, 25-30% if you like it how vv make it.
Has been a while since I had the Pre-Mixed stuff but mixed a batch at 20% and it's spot on, gone through a tank of it seems to be a shake and vape mix but I will add it to the stock pile and come back later :p
Really impressed with the Griffin, so much room for activities on that deck! I know some people say the flavour is "almost" as good as the Crius but in my opinion with the builds the Griffin allows you to do compared to the Crius i'd say better if you get creative.
It is shake and vape, though I give it 2-3 days for good measure :)
Speaking of which I'd best get some more pinkman ordered up, nearly finished the last 100ml I made.
Mine came with a 0.4...
Probably better in terms of vapour and flavour, yes, but almost certainly not in terms of juice economy!
I haven't even tried my 0.2 yet! :D
55-70w, surely? It says so on the side.
0.4ohm is 40-60w, although it fires reasonably well as low as 20w.
Tony from Vapour Depot who sold it to me mentioned he drives his cleito at 50W .2ohm
Letting my liquids steep at the moment. I wanna get an rebuidable coil tank, whats the best? I want airflow and not a tight draw.
Crius, bellus, Griffin, Aromamizer and VCMT in no particular order as I haven't bothered trying them all as I prefer I tigher DTL draw
Right guys, I've been off the analogues since Monday. I was on 20 Lambert & Butler a day, for gosh, 19 years or so. I'm using a Kanger Kbox Mini.
I'm currently using Ace of Vapez liquids at 12MG. I bought three; Wolf Astaire, Wolf Astaire Fruit and Yoda Snot. I've only tried Wolf Astaire so far, since Monday.
Whilst the flavours are fun, they're not the nicest after a meal or glass of wine which is really where I miss my analogues the most.
I'd like some advice please...
  • Which is considered the best tobacco flavour, ideally something similar in taste to Lambert & Butler, Regal, Embassy etc?
  • When I move on to a different flavour, how should I best wash out the tank and coil? Flush with water or use vodka as I have seen suggested.
  • I'm currently vaping at 14W. Mostly hitting the spot. Strangely though, sometimes I can sit and vape for a long time, others I cough repeatedly. Is this normal? It seems sometimes the hits are stronger than others despite vaping at the same wattage :confused:
  • I'm using 0.5 resistance coils. I still don't really understand the difference despite reading up. Any short, factual tips?
Status
