- 15 Jul 2006
- Up Carp Creek
Tried Vape Goo Cinnamon Danish Swirl after a 6 day steep, very very nice.
Anyone using a Wismec Reuleaux DNA 200? Any issues\feedback on it?
Looking for a regulated multi-battery solution as I'm getting fed up with changing batteries on the Sigelei 75w during the day.
I have two of the DNA200 Reuleaux's, both have been working great and around 40-60w i get lots of battery life using samsung 30q batteries or Efest 20800mAh cells, heck even with VTC3 cells it still last longer than most dual cell mods..
The only negative i would give the mod is the battery fittings, it can damage your battery wraps too easily if your not carefull.
I looked at the RX, some were saying that charging it off USB is an issue? Doesn't balance the batteries right or something? Normally I use an external charger, but I do work some stupidly long hours sometimes!
So I finally got my hands on my VTC Mini and Clieto last night, coming from the pretty simple Subvod I'm a bit overwhelmed with all the settings...What temp do we all like to tonk on? Messing about around 200-220 on about 42W and I'm getting some pretty decent flavours and clouds.
Anyone ever had the phenominon of juice becoming more concentrated as it vapes?
I've a few juices do it, they get darker with more intense flavour as you vape them, not sure if theres anything to be done about it though, hence the question.
Current tankful turned from golden to crude oil today during use
Chaning colour when it's inside the tank is a sign of dirty wick/coils
Something like sweet in the Serpent sees me needing to dry burn and rewick every 3rd tank or so
The Clieto doesn't have temperature coils so I'm unsure how you are doing this. They are normal Kanthal. Temperature will do nothing.
50W to 60W works well on the 0.4 Ohm coils
80W+ on the 0.25 Ohm coils
Problem with that is its a fresh wick in here.
Dont really mind, just curious, i do have an issue with spitting at 1/3 tank capacity but bizarrely it dissapears above or below that level, and only happens on certain juices.
Ahh well, intensifying flavour aint so bad tbh
It may be due to the constant burst of high temperatures coupled with oxygen through the air holes while being in the tank, kind of a 'speed-steeping'. Just a theory though
What mg nic do you use? I'd imagine the colouration change would be more prevalent in juices that are higher in nic.
