- 2 Feb 2010
- Crowmarsh
I cannot find the right BTU ROM anywhere
Can you not use Kies to do a emergency fw repair, it goes by your serial.
Will put original fw back onto phone at least.
Slow dl speed but here is the BTU if you want to try odin again.
http://www.sammobile.com/firmwares/database/SM-G920F/BTU/
Also french csc is XEF, but double check.
http://www.sammobile.com/firmwares/database/SM-G920F/XEF/
If you're happy enough with XEF (which is what I have) then there's a fairly good download link in the xda S6 firmwares section (in the general forum) .
It installed and is working but screen touch calibration is all mirrored back to front![]()
You sure you downloaded the right firmware? You're normal S6, right (G920F)?
Did you get the XEF from this page?
http://forum.xda-developers.com/showpost.php?p=65397382&postcount=2
Alternatively, check this thread:
http://forum.xda-developers.com/galaxy-s6/help/touchscreenaxes-inverted-t3086450
Advice from that thread seems to be:
"Dial *#2663# in the dialer and update the thouch screen panel firmware by selecting 'TSP FW update (General)' button"
You are a lifesaver! Can't thank you enough!
It works ok after doing that!
Many thanks!
Ah that's brilliant!! Happy to be able to help.
Just bought a new sd card for my s6 since the current one is almost full. What is the best way to transfer the data from the old card to the new one?
microSd card then whatever.
