best wireless = astro A50.
I'm looking into upgrading my headset, I currently have the Sony pulse headset (gta v version but identical internally) would a set of A50's be a noticeable upgrade?
I have heard about an issue with a hum when in use, if this is true how bad is it as I wouldn't want to be spending £200 to have a headset with a background hum.
Ita not an essential upgrade just a treat to myself, I like the pulse as I can just pick them up but I like the idea of having something on a stand I can use whenever I fancy and it has its own holder and is top quality.
depends on how good your ears are and if you tune yourself to noticing the differences.
for example i could show a reference quality 50" plasma to someone then a £300 50" polaroid tv and they not see any difference.
if you know what to look for then yes the difference will be noticeable.
however wired beats wireless by miles £ for £. wireless however has the advantage of no wires.
i don't know how the A50's work they could possibly connect by wire to the controller. which doesn't mean true wireless
Thanks for the detailed reply Sonny. I have gotten used to having the virtual surround and quite enjoy it, especially in open world games like Fallout as I can tell what's going on and where generally.
It's quite hard to decide but I suppose the advantage of having a mixamp anyway is you can turn the DSS off and still use chat.
I saw you can connect a mixamp+dac+amp on HeadFi. Does that mean the mixamp will just be used for chat at that point and the DAC takes over or?
I may go with a Schiit Magni/Modu Uber stack. I'm not entirely convinced I would miss DSS. I remember flicking between stereo and DSS on Tomb Raider and thought stereo sounded better and I could still tell where hte drips were coming from. I only need voice now and then so maybe I could go with the usb mic route and avoid buying the mixamp.
I see. I'll put the mixamp off for now then. Thanks again.
the k702 all the way then.
make sure you do the bass mod and your sorted.
mod involves removing a bit of film with some tweezers.
i would get a matching schiit optical DAC
the best thing you can do is grab some powerful music and head down to richer sounds and test out their dac/amps with your headphones.
you will then see for yourself the kind of difference they make.
what headphones do you own or are thinking of buying?
the chain is only as strong as it's weakest link.
media - source - DAC - AMP - headphones
all of them should be on the same level. for instance you wouldn't play magnetic tape through £10,000 speakers. the same you wouldn't use a £100 DAC with £20 headphones.
Had X1's my first decent headphone barring a brief spell with some AT M50's (which made my ears really hot).
AKG K712 Pro has been ordered, I also like the look of X2, K702 (cheaper too as a +).
How the **** do I connect any kind of much to these with that xlr connection?
