Just got an update - 74.38mb Just says device stability improvements etc.
Were you on G935FXXU1APAW before the update?
Updating now. Was on PAW.
Spigen case review is now also up!
http://www.neowin.net/news/spigen-thin-fit-case-for-galaxy-s7-edge-review
And yes, I've changed my mind and will be using the Thin Fit often because of the earlier mentioned incident![]()
Also got the update.
Why install more bloat when there's barely any on these devices anyway?
There's still loads of crapware on Samsung devices.
Do you actually own one? Cause I'm struggling to find any crapware on my device![]()
Yes I have the s7 edge and the app removed 80 apps or so of rubbish whether it be Samsung of Google.
Problem is there are so many things that can effect the battery life between different users even with the same phone..If you had wifi on and a semi-decent signal I would say that was pretty poor personally. I'd guess my 6P would beat that with similar usage.
